Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
for details.
PR 1924/cpukit
* spstkalloc02/.cvsignore, spstkalloc02/Makefile.am,
spstkalloc02/init.c, spstkalloc02/spstkalloc02.doc,
spstkalloc02/spstkalloc02.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
