path: root/testsuites/sptests/spstkalloc02 (follow)
* spstkalloc02/init.c: Fix printf() format warningsJoel Sherrill2017-08-271-6/+6
* Prefix confdefs.h internal def with an underscoreSebastian Huber2017-02-031-2/+2
| | | | Close #2895.
* sptests/spstkalloc02: Fix namespace issueSebastian Huber2015-04-271-3/+3
| | | | Avoid collision with <sys/param.h> defined PAGE_SIZE.
* testsuites: Remove BSP_SMALL_MEMORYJoel Sherrill2014-05-061-25/+0
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-3/+7
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* score: Create heap implementation headerSebastian Huber2013-07-231-1/+1
| | | | | | Move implementation specific parts of heap.h and heap.inl into new header file heapimpl.h. The heap.h contains now only the application visible API.
* sptests/spstkalloc02: Disable for small memory BSPSebastian Huber2013-04-081-0/+25
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* Typo.Sebastian Huber2011-12-142-4/+4
* 2011-12-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-12-145-0/+215
PR 1924/cpukit * spstkalloc02/.cvsignore, spstkalloc02/Makefile.am, spstkalloc02/init.c, spstkalloc02/spstkalloc02.doc, spstkalloc02/spstkalloc02.scn: New files. * Makefile.am, configure.ac: Reflect changes above.
