the application requires rtems to allocate a trap table
_Thread_Ticks_remaining_in_timeslice.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
variables and renaming of others.
single enumerated set of states the set of event manager variables changed.
like signal dispatching.
