path: root/testsuites/sptests/spsem_err02 (follow)
* tests: Use rtems_task_exit()Sebastian Huber2018-10-051-2/+1
| | | | Update #3533.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* Replace www.rtems.com with www.rtems.orgSebastian Huber2015-03-203-3/+3
* sptests: Add missing test extensionSebastian Huber2015-02-191-0/+2
* sptests: split sp09 screen 5,6 into spsem_err01, spsem_err02, and sptask_err01.Bjorn Larsson2014-03-286-0/+327
sp09 screen 5 split into spsem_err01, sp09 screen 6 split into spsem_err02, and sptask_err01.
