path: root/testsuites/sptests/spsem03 (follow)
* sptests/spsem03: Fix compile errorSebastian Huber2016-09-231-1/+1
* score: Rework thread priority managementSebastian Huber2016-09-212-17/+17
| | | | | | | | | | | | | | | | | | | | | | | | | Add priority nodes which contribute to the overall thread priority. The actual priority of a thread is now an aggregation of priority nodes. The thread priority aggregation for the home scheduler instance of a thread consists of at least one priority node, which is normally the real priority of the thread. The locking protocols (e.g. priority ceiling and priority inheritance), rate-monotonic period objects and the POSIX sporadic server add, change and remove priority nodes. A thread changes its priority now immediately, e.g. priority changes are not deferred until the thread releases its last resource. Replace the _Thread_Change_priority() function with * _Thread_Priority_perform_actions(), * _Thread_Priority_add(), * _Thread_Priority_remove(), * _Thread_Priority_change(), and * _Thread_Priority_update(). Update #2412. Update #2556.
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-2/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* sptests/spsem03: New testSebastian Huber2014-06-034-0/+192
