path: root/testsuites/sptests/sprmsched02 (follow)
* sptests: Remove CONFIGURE_MILLISECONDS_PER_TICKSebastian Huber2018-05-281-2/+0
| | | | This configuration define is not supported.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* rtems: Fix _Rate_monotonic_Renew_deadline()Kuan-Hsun Chen2017-01-304-0/+169
Prepare a precondition to prevent the potential integer overflow. Remove one redundant parameter in _Rate_monotonic_Renew_deadline(). sptests/sprmsched02: Create A test case for checking the overflow condition of postponed_jobs in rtems_rate_monotonic_period_status. Update #2885.
