* | sprmsched01/spedfsched04: Revise | Kuan-Hsun Chen | 2017-01-31 | 3 | -88/+42 |
| | | | | | | | | Instead of using the target time and console driver, both tests now use assertions and rtems_rate_monotonic_get_status() to verify the count of postponed jobs. The setting of spedfsched04 is slightly changed. Close #2795. | ||||
* | sptests/sprmsched01: Merge and fix | Sebastian Huber | 2017-01-24 | 4 | -196/+112 |
| | | | | | | | Merge into one file and fix obvious problems (e.g. out of bounds array access). Update #2795. | ||||
* | classic: adjust names of RM postponed job functions | Gedare Bloom | 2017-01-13 | 1 | -3/+3 |
| | | | | closes #2795 | ||||
* | sptests: rate monotonic scheduler overrun handling | Kuan-Hsun Chen | 2017-01-13 | 6 | -0/+347 |
Update #2795. |
