* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -1/+3 |
* | spqreslib - Make global data extern in system.h | Joel Sherrill | 2012-05-09 | 1 | -2/+7 |
| | | | | | | Global data was declared in system.h but should have been extern in system.h and declared in init.c. There were duplicate symbol linking errors on at least powerpc/mpc8260ads. | ||||
* | PR1908: QoS library for CBS scheduler | Petr Benes | 2012-04-15 | 1 | -0/+227 |
Add the lipqos and sptest. |
