* | score: Add _IO_Base64url() | Sebastian Huber | 2021-02-25 | 1 | -0/+12 |
| | | | | Update #4267. | ||||
* | score: Add _IO_Base64() | Sebastian Huber | 2020-03-16 | 1 | -0/+56 |
| | | | | Update #3904. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | score: Add _IO_Printf() and _IO_Vprintf() | Sebastian Huber | 2017-11-06 | 2 | -92/+150 |
| | | | | | | | | | | | | | | The previous vprintk() implementation had a questionable licence header, lacks support for the 'z' and 'j' format specifiers, is not robust against invalid format specifiers, uses a global variable for output. Replace it with a stripped down version of the FreeBSD kernel kvprintf() function. The new implementation allows a low overhead rtems_snprintf() if necessary. Update #3199. Close #3216. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | tests: Remove obsolete TESTS_USE_PRINTK | Sebastian Huber | 2017-10-28 | 1 | -1/+0 |
* | tests: Use rtems_test_printer in general | Sebastian Huber | 2017-10-28 | 1 | -0/+1 |
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | Make rtems/print.h independent of rtems/bspIo.h | Sebastian Huber | 2016-06-22 | 1 | -1/+0 |
* | Rename and move RTEMS_PRINTF_ATTRIBUTE() | Sebastian Huber | 2016-06-22 | 1 | -3/+5 |
| | | | | | Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to <sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>. | ||||
* | testsuite: Fix printk format warnings. | Chris Johns | 2016-05-25 | 1 | -6/+6 |
* | cpukit, testsuite: Add rtems_printf and rtems_printer support. | Chris Johns | 2016-05-25 | 1 | -5/+12 |
| | | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work. | ||||
* | sptests/spprintk: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+4 |
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -0/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | printk: Add support for long long | Sebastian Huber | 2014-03-11 | 2 | -0/+49 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -0/+7 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-07-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-14 | 3 | -10/+56 |
| | | | | | * spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean up and add test of getchark(). | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-11-09 | 1 | -1/+1 |
| | | | | * spprintk/spprintk.scn: Add end of line at end of file. | ||||
* | 2009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-11-09 | 2 | -0/+23 |
| | | | | | | | | | | | | | | | | | | | | * sp32/Makefile.am, sp33/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spsize/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Add documentation files for multiple tests. * sp32/sp32.doc, sp33/sp33.doc, sp37/sp37.doc, sp38/sp38.doc, sp39/sp39.doc, sp43/sp43.doc, sp44/sp44.doc, spfatal01/spfatal01.doc, spfatal02/spfatal02.doc, spfatal03/spfatal03.doc, spfatal04/spfatal04.doc, spfatal05/spfatal05.doc, spfatal06/spfatal06.doc, spfatal07/spfatal07.doc, spfatal08/spfatal08.doc, spfatal09/spfatal09.doc, spobjgetnext/spobjgetnext.doc, spprintk/spprintk.doc, spsize/spsize.doc, spwatchdog/spwatchdog.doc, spwkspace/spwkspace.doc: New files. | ||||
* | Eliminate unused vars. | Ralf Corsepius | 2009-10-24 | 1 | -4/+0 |
* | 2009-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-06-24 | 2 | -1/+34 |
| | | | | | | | | * Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn: Enhance spprintk. Add two new fatal error tests to cover __assert_func. * spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c, spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files. | ||||
* | 2009-05-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-15 | 1 | -0/+14 |
| | | | | * spprintk/init.c: printk() now 100% covered. | ||||
* | 2009-05-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-14 | 1 | -4/+19 |
| | | | | * spprintk/init.c: More test cases. | ||||
* | 2009-05-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-14 | 4 | -0/+74 |
* Makefile.am, configure.ac, spwatchdog/system.h, spwkspace/Makefile.am, spwkspace/init.c: Add shell of test for printk. These will help coverage. Simplify spwkspace. * spprintk/.cvsignore, spprintk/Makefile.am, spprintk/init.c, spprintk/spprintk.scn: New files. * spwkspace/system.h: Removed. |
