* spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean
up and add test of getchark().
* Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn:
Enhance spprintk. Add two new fatal error tests to cover
__assert_func.
* spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c,
spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files.
* spprintk/init.c: printk() now 100% covered.
* spprintk/init.c: More test cases.
* Makefile.am, configure.ac, spwatchdog/system.h,
spwkspace/Makefile.am, spwkspace/init.c: Add shell of test for
printk. These will help coverage. Simplify spwkspace.
* spprintk/.cvsignore, spprintk/Makefile.am, spprintk/init.c,
spprintk/spprintk.scn: New files.
* spwkspace/system.h: Removed.
