path: root/testsuites/sptests/spnsext01 (follow)
* tests: Remove CONFIGURE_MAXIMUM_DRIVERSSebastian Huber2018-08-071-1/+0
| | | | This configuration is superfluous in these tests.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-21/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* tests: Fix warningsSebastian Huber2015-03-051-1/+1
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-2/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* score: Add SMP lock profiling supportSebastian Huber2014-03-141-1/+1
* score: Add function to destroy SMP locksSebastian Huber2014-03-111-0/+1
* score: Add local context to SMP lock APISebastian Huber2014-03-111-4/+5
| | | | | | | | | | | Add a local context structure to the SMP lock API for acquire and release pairs. This context can be used to store the ISR level and profiling information. It may be later used to enable more sophisticated lock algorithms, e.g. MCS locks. There is only one lock that cannot be used with a local context. This is the per-CPU lock since here we would have to transfer the local context through a context switch which is very complicated.
* sptests/spnsext01: Add SMP supportSebastian Huber2013-08-271-2/+3
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* 2011-09-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-141-2/+2
| | | | * spnsext01/init.c: Use correct API.
* 2011-05-06 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-065-0/+146
* spnsext01/.cvsignore, spnsext01/Makefile.am, spnsext01/init.c, spnsext01/spnsext01.doc, spnsext01/spnsext01.scn: New files. * Makefile.am, configure.ac: Reflect changes above.
