Update #3382
The _Semaphore_Get_operations() must return the proper operations for
priority inheritance semaphores.
Add a test case for rtems_semaphore_flush() with priority inheritance.
Close #3235.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
Update #2825.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
The mutex objects use the owner field of the thread queues for the mutex
owner. Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
The priority inheritance and ceiling CORE mutexes wrongly used the FIFO
queueing discipline. Delete misleading _CORE_mutex_Is_priority(). Bug
introduced by 1e1a91ed11458ddbb27b94d0001d8f0fc2ef7a97.
Add test sptests/spmutex01, since no existing uni-processor test covered
the thread priority queueing discipline for CORE mutexes.
