GCC 11 produced warnings like this:
items.c:21:1: warning: ignoring attribute
'section (".rtemsrwset.test_rw.content.0.1")' because it conflicts with
previous 'section (".rtemsrwset.test_rw.content.1")' [-Wattributes]
items.c:23:1: warning: ignoring attribute
'section (".rtemsroset.test_ro.content.0.OC")' because it conflicts with
previous 'section (".rtemsroset.test_ro.content.1")' [-Wattributes]
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Update #3082.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Resurrect RTEMS_LINKER_SET_BEGIN() and RTEMS_LINKER_SET_END().
Add new macros RTEMS_LINKER_SET_ITEM_COUNT(),
RTEMS_LINKER_SET_IS_EMPTY(), and
RTEMS_LINKER_SET_FOREACH().
Remove confusing RTEMS_LINKER_SET_ASSIGN_BEGIN() and
RTEMS_LINKER_SET_ASSIGN_END().
Fix RTEMS_LINKER_SET_SIZE() to return the size in characters as
specified by the documentation.
Update #2408.
Update #2790.
Update #2408.
Update #2790.
The newly created macro adds any kind of variable into a linker set. It
allows (for example) the saving an execution state of a function using
the following method:
- put a group of different variables into one linker set
- save the memory area containing the group of variables before the
execution of a function
- restore the memory area after the function has been executed
Update #2408.
