Extract this function from
interrupt_critical_section_test_support_initialize().
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
* spintrcritical_support/intrcritical.c: Fixed timing rountines.
* spintrcritical_support/intrcritical.c,
spintrcritical_support/intrcritical.h: Change prototype of delay
method to indicate when counter is reset. This can be used to count
how many iterations we are doing.
spintrcritical_support/intrcritical.h: New files.
