* | score: New thread queue implementation | Sebastian Huber | 2015-05-19 | 1 | -24/+13 |
| | | | | | | | | | Use thread wait flags for synchronization. The enqueue operation is now part of the initial critical section. This is the key change and enables fine grained locking on SMP for objects using a thread queue like semaphores and message queues. Update #2273. | ||||
* | tests: Rework interrupt critical tests | Sebastian Huber | 2014-09-10 | 1 | -17/+15 |
| | | | | | | | | | This avoids test durations of more than one hour on fast targets, since fast targets can count a lot during one clock tick period, so the minor loop iteration count was quite high. Estimate now the test body duration to iterate only through the interesting time window. Add and use interrupt_critical_section_test(). | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -4/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__ | Sebastian Huber | 2013-08-08 | 1 | -1/+0 |
* | testsuites: Use _Thread_Get_executing() | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
* | rtems: Create semaphore implementation header | Sebastian Huber | 2013-07-18 | 1 | -0/+2 |
| | | | | | | Move implementation specific parts of sem.h and sem.inl into new header file semimpl.h. The sem.h contains now only the application visible API. | ||||
* | sptests/spintrcritical16: Fix NULL pointer access | Sebastian Huber | 2013-01-02 | 1 | -1/+4 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -0/+5 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -0/+1 |
| | | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | 2009-09-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-27 | 1 | -0/+1 |
| | | | | | * sp59/init.c, spintrcritical15/init.c, spintrcritical16/init.c: Correct minor issues uncovered on uC5282. | ||||
* | 2009-07-30 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-30 | 1 | -3/+1 |
| | | | | * spintrcritical16/spintrcritical16.doc: Remove junk and typos. | ||||
* | 2009-07-30 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-30 | 1 | -1/+1 |
| | | | | | * spintrcritical16/init.c: Tinker with test to make it hit the case more reliably. | ||||
* | 2009-07-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-28 | 5 | -0/+181 |
* Makefile.am, configure.ac: Add test case for processing a timeout on a thread (that is the thread executing) that has also had its request satisfied while it is being enqueued. * spintrcritical16/.cvsignore, spintrcritical16/Makefile.am, spintrcritical16/init.c, spintrcritical16/spintrcritical16.doc, spintrcritical16/spintrcritical16.scn: New files. * spintrcritical15/init.c: Remove unused TSR> |
