* | sptests: Avoid build system defined defines | Sebastian Huber | 2019-11-12 | 2 | -96/+98 |
| | | | | Update #3818. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -25/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | tests: Rework interrupt critical tests | Sebastian Huber | 2014-09-10 | 1 | -11/+13 |
| | | | | | | | | | This avoids test durations of more than one hour on fast targets, since fast targets can count a lot during one clock tick period, so the minor loop iteration count was quite high. Estimate now the test body duration to iterate only through the interesting time window. Add and use interrupt_critical_section_test(). | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -1/+5 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -0/+1 |
| | | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-07-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-14 | 1 | -0/+1 |
| | | | | | | | | | | | | * spintrcritical06/init.c: Switch semaphore obtain timeouts of variants. Cleanup. * spintrcritical05/spintrcritical05.scn, spintrcritical06/spintrcritical06.scn, spintrcritical07/spintrcritical07.scn, spintrcritical11/spintrcritical11.scn, spintrcritical12/spintrcritical12.scn, spintrcritical13/spintrcritical13.scn, spintrcritical14/spintrcritical14.scn: Update. | ||||
* | Eliminate unused vars. | Ralf Corsepius | 2009-10-24 | 1 | -1/+0 |
* | 2009-10-04 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2009-10-05 | 1 | -2/+0 |
| | | | | | | | * sptests/spintrcritical09/init.c, sptests/spintrcritical10/init.c, sptests/spintrcritical11/init.c: Fixed potentially infinite loops. * sp20/system.h: Increased micro seconds per tick in order to be more independent of the console output speed. | ||||
* | 2009-07-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-21 | 5 | -0/+148 |
* Makefile.am, configure.ac, sp39/init.c, sp39/sp39.scn: Move unreliable third case in sp39 to spintrcritical10. New tests to hit other event synchronization critical sections. * spintrcritical11/.cvsignore, spintrcritical11/Makefile.am, spintrcritical11/init.c, spintrcritical11/spintrcritical11.doc, spintrcritical11/spintrcritical11.scn, spintrcritical12/.cvsignore, spintrcritical12/Makefile.am, spintrcritical12/spintrcritical12.doc, spintrcritical12/spintrcritical12.scn: New files. |
