Theses files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
Update #3818.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
* sptests/spintrcritical09/init.c, sptests/spintrcritical10/init.c,
sptests/spintrcritical11/init.c: Fixed potentially infinite loops.
* sp20/system.h: Increased micro seconds per tick in order to be more
independent of the console output speed.
* Makefile.am, configure.ac, sp39/init.c, sp39/sp39.scn: Move
unreliable third case in sp39 to spintrcritical10. New tests to hit
other event synchronization critical sections.
* spintrcritical11/.cvsignore, spintrcritical11/Makefile.am,
spintrcritical11/init.c, spintrcritical11/spintrcritical11.doc,
spintrcritical11/spintrcritical11.scn, spintrcritical12/.cvsignore,
spintrcritical12/Makefile.am, spintrcritical12/spintrcritical12.doc,
spintrcritical12/spintrcritical12.scn: New files.
