* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | score: Rename watchdog variants | Sebastian Huber | 2017-10-17 | 1 | -1/+1 |
| | | | | | | | | | | | Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to highlight the corresponding POSIX CLOCK_MONOTONIC. Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to highlight the corresponding POSIX CLOCK_REALTIME. Update #3117. Update #3182. | ||||
* | score: Replace watchdog handler implementation | Sebastian Huber | 2016-03-04 | 1 | -14/+13 |
| | | | | | | | | | Use a red-black tree instead of delta chains. Close #2344. Update #2554. Update #2555. Close #2606. | ||||
* | score: New thread queue implementation | Sebastian Huber | 2015-05-19 | 1 | -16/+12 |
| | | | | | | | | | Use thread wait flags for synchronization. The enqueue operation is now part of the initial critical section. This is the key change and enables fine grained locking on SMP for objects using a thread queue like semaphores and message queues. Update #2273. | ||||
* | score: Add header to _Watchdog_Remove() | Sebastian Huber | 2015-05-19 | 1 | -1/+1 |
| | | | | | | | | Add watchdog header parameter to _Watchdog_Remove() to be in line with the other operations. Add _Watchdog_Remove_ticks() and _Watchdog_Remove_seconds() for convenience. Update #2307. | ||||
* | score: Add Watchdog_Header | Sebastian Huber | 2015-04-13 | 1 | -3/+3 |
| | | | | | | | This type is intended to encapsulate all state to manage a watchdog chain. Update #2307. | ||||
* | tests: Rework interrupt critical tests | Sebastian Huber | 2014-09-10 | 1 | -12/+12 |
| | | | | | | | | | This avoids test durations of more than one hour on fast targets, since fast targets can count a lot during one clock tick period, so the minor loop iteration count was quite high. Estimate now the test body duration to iterate only through the interesting time window. Add and use interrupt_critical_section_test(). | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__ | Sebastian Huber | 2013-08-08 | 1 | -1/+0 |
* | score: Create watchdog implementation header | Sebastian Huber | 2013-07-22 | 1 | -0/+1 |
| | | | | | | Move implementation specific parts of watchdog.h and watchdog.inl into new header file watchdogimpl.h. The watchdog.h contains now only the application visible API. | ||||
* | rtems: Create semaphore implementation header | Sebastian Huber | 2013-07-18 | 1 | -0/+2 |
| | | | | | | Move implementation specific parts of sem.h and sem.inl into new header file semimpl.h. The sem.h contains now only the application visible API. | ||||
* | sptests/spintrcritical09: Fix check order | Sebastian Huber | 2012-11-13 | 1 | -17/+25 |
| | | | | | | The critical section check never succeeded since watchdogs are ordered with respect to the insertion time. Now we call the watchdog routine if appropriate and bypass the normal watchdog mechanic. | ||||
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -1/+6 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -0/+1 |
| | | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | 2009-10-04 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2009-10-05 | 1 | -2/+0 |
| | | | | | | | * sptests/spintrcritical09/init.c, sptests/spintrcritical10/init.c, sptests/spintrcritical11/init.c: Fixed potentially infinite loops. * sp20/system.h: Increased micro seconds per tick in order to be more independent of the console output speed. | ||||
* | 2009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-23 | 1 | -5/+5 |
| | | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical09/init.c: Perform some cleanup and make the tests more similar. | ||||
* | 2009-07-22 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-22 | 2 | -34/+10 |
| | | | | | * spintrcritical09/init.c, spintrcritical09/spintrcritical09.scn: Make test work for case that it is documented to handle. | ||||
* | 2009-07-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-21 | 2 | -1/+8 |
| | | | | | | * spintrcritical06/init.c: Clean up. * spintrcritical09/init.c: Adjust clock tick so it works on erc32. * spintrcritical09/spintrcritical09.scn: Fill in. | ||||
* | 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-21 | 5 | -0/+184 |
* spintrcritical06/init.c: Add comment to indicate test is not finished and known to not hit the case. * Makefile.am, configure.ac: Add a couple more interrupt critical section tests. * spintrcritical08/.cvsignore, spintrcritical08/Makefile.am, spintrcritical08/init.c, spintrcritical08/spintrcritical08.doc, spintrcritical08/spintrcritical08.scn, spintrcritical09/.cvsignore, spintrcritical09/Makefile.am, spintrcritical09/init.c, spintrcritical09/spintrcritical09.doc, spintrcritical09/spintrcritical09.scn: New files. |
