* | 2009-07-22 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-22 | 1 | -3/+1 |
| | | | | | * spintrcritical09/init.c, spintrcritical09/spintrcritical09.scn: Make test work for case that it is documented to handle. | ||||
* | 2009-07-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-21 | 1 | -0/+6 |
| | | | | | | * spintrcritical06/init.c: Clean up. * spintrcritical09/init.c: Adjust clock tick so it works on erc32. * spintrcritical09/spintrcritical09.scn: Fill in. | ||||
* | 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-21 | 1 | -0/+0 |
* spintrcritical06/init.c: Add comment to indicate test is not finished and known to not hit the case. * Makefile.am, configure.ac: Add a couple more interrupt critical section tests. * spintrcritical08/.cvsignore, spintrcritical08/Makefile.am, spintrcritical08/init.c, spintrcritical08/spintrcritical08.doc, spintrcritical08/spintrcritical08.scn, spintrcritical09/.cvsignore, spintrcritical09/Makefile.am, spintrcritical09/init.c, spintrcritical09/spintrcritical09.doc, spintrcritical09/spintrcritical09.scn: New files. |
