* | spintrcritical08: Increase clock tick interval | Sebastian Huber | 2020-09-10 | 1 | -1/+1 |
| | | | | | On some simulators, a clock tick interval of 1ms seems to be too short. For example, the test failed on sparc/erc32 using the SIS. | ||||
* | spintrcritical08: Use T_interrupt_test() | Sebastian Huber | 2020-07-23 | 2 | -80/+156 |
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -25/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | score: Introduce new monotonic clock | Sebastian Huber | 2018-02-02 | 1 | -2/+2 |
| | | | | | | | | Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured by timecounter). Close #3264. | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | score: Rename watchdog variants | Sebastian Huber | 2017-10-17 | 1 | -2/+2 |
| | | | | | | | | | | | Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to highlight the corresponding POSIX CLOCK_MONOTONIC. Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to highlight the corresponding POSIX CLOCK_REALTIME. Update #3117. Update #3182. | ||||
* | rtems: Rework rate-monotonic scheduler | Sebastian Huber | 2016-03-22 | 1 | -12/+20 |
| | | | | | | | | | | Use the default thread lock to protect rate-monotonic state changes. This avoids use of the Giant lock. Split rtems_rate_monotonic_period() body into several static functions. Introduce a new thread wait class THREAD_WAIT_CLASS_PERIOD for period objects to synchronize the blocking operation. Close #2631. | ||||
* | score: Replace watchdog handler implementation | Sebastian Huber | 2016-03-04 | 1 | -14/+12 |
| | | | | | | | | | Use a red-black tree instead of delta chains. Close #2344. Update #2554. Update #2555. Close #2606. | ||||
* | score: Add header to _Watchdog_Remove() | Sebastian Huber | 2015-05-19 | 1 | -1/+1 |
| | | | | | | | | Add watchdog header parameter to _Watchdog_Remove() to be in line with the other operations. Add _Watchdog_Remove_ticks() and _Watchdog_Remove_seconds() for convenience. Update #2307. | ||||
* | score: Add Watchdog_Header | Sebastian Huber | 2015-04-13 | 1 | -3/+3 |
| | | | | | | | This type is intended to encapsulate all state to manage a watchdog chain. Update #2307. | ||||
* | tests: Rework interrupt critical tests | Sebastian Huber | 2014-09-10 | 1 | -25/+45 |
| | | | | | | | | | This avoids test durations of more than one hour on fast targets, since fast targets can count a lot during one clock tick period, so the minor loop iteration count was quite high. Estimate now the test body duration to iterate only through the interesting time window. Add and use interrupt_critical_section_test(). | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__ | Sebastian Huber | 2013-08-08 | 1 | -1/+0 |
* | rtems: Create ratemon implementation header | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
| | | | | | | Move implementation specific parts of ratemon.h and ratemon.inl into new header file ratemonimpl.h. The ratemon.h contains now only the application visible API. | ||||
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -1/+6 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -0/+1 |
| | | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | 2009-08-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-06 | 1 | -0/+1 |
| | | | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds per tick so tests run quicker and more reliably hit the intended critical section. | ||||
* | 2009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-23 | 1 | -1/+2 |
| | | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical09/init.c: Perform some cleanup and make the tests more similar. | ||||
* | 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-21 | 5 | -0/+161 |
* spintrcritical06/init.c: Add comment to indicate test is not finished and known to not hit the case. * Makefile.am, configure.ac: Add a couple more interrupt critical section tests. * spintrcritical08/.cvsignore, spintrcritical08/Makefile.am, spintrcritical08/init.c, spintrcritical08/spintrcritical08.doc, spintrcritical08/spintrcritical08.scn, spintrcritical09/.cvsignore, spintrcritical09/Makefile.am, spintrcritical09/init.c, spintrcritical09/spintrcritical09.doc, spintrcritical09/spintrcritical09.scn: New files. |
