brains GmbH.
Updates #3053.
Remove the THREAD_WAIT_STATE_READY_AGAIN and simply use the initial value to
indicate that a thread does not wait on something. Rename
THREAD_WAIT_FLAGS_INITIAL to THREAD_WAIT_STATE_READY. This change is necessary
so that _Thread_Continue() can be called for threads which never waited on
something (for example dormant threads).
Update #4546.
On some simulators, a clock tick interval of 1ms seems to be too short.
For example, the test failed on sparc/erc32 using the SIS.
Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new
PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured
by timecounter).
Close #3264.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to
highlight the corresponding POSIX CLOCK_MONOTONIC.
Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to
highlight the corresponding POSIX CLOCK_REALTIME.
Update #3117.
Update #3182.
Use the default thread lock to protect rate-monotonic state changes.
This avoids use of the Giant lock. Split rtems_rate_monotonic_period()
body into several static functions. Introduce a new thread wait class
THREAD_WAIT_CLASS_PERIOD for period objects to synchronize the blocking
operation.
Close #2631.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Add watchdog header parameter to _Watchdog_Remove() to be in line with
the other operations. Add _Watchdog_Remove_ticks() and
_Watchdog_Remove_seconds() for convenience.
Update #2307.
This type is intended to encapsulate all state to manage a watchdog
chain.
Update #2307.
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
Move implementation specific parts of ratemon.h and ratemon.inl into
new header file ratemonimpl.h. The ratemon.h contains now only the
application visible API.
* spintrcritical01/init.c, spintrcritical06/init.c,
spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds
per tick so tests run quicker and more reliably hit the intended
critical section.
spintrcritical08/init.c, spintrcritical09/init.c: Perform some
cleanup and make the tests more similar.
* spintrcritical06/init.c: Add comment to indicate test is not finished
and known to not hit the case.
* Makefile.am, configure.ac: Add a couple more interrupt critical
section tests.
* spintrcritical08/.cvsignore, spintrcritical08/Makefile.am,
spintrcritical08/init.c, spintrcritical08/spintrcritical08.doc,
spintrcritical08/spintrcritical08.scn, spintrcritical09/.cvsignore,
spintrcritical09/Makefile.am, spintrcritical09/init.c,
spintrcritical09/spintrcritical09.doc,
spintrcritical09/spintrcritical09.scn: New files.
