path: root/testsuites/sptests/spintrcritical06 (follow)
* tests: Rework interrupt critical testsSebastian Huber2014-09-101-13/+15
| | | | | | | | | This avoids test durations of more than one hour on fast targets, since fast targets can count a lot during one clock tick period, so the minor loop iteration count was quite high. Estimate now the test body duration to iterate only through the interesting time window. Add and use interrupt_critical_section_test().
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-4/+8
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__Sebastian Huber2013-08-081-1/+0
* sptests - Eliminate missing prototype warningsJoel Sherrill2012-05-311-1/+6
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-201-0/+1
| | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-07-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-07-142-27/+8
| | | | | | | | | | | | * spintrcritical06/init.c: Switch semaphore obtain timeouts of variants. Cleanup. * spintrcritical05/spintrcritical05.scn, spintrcritical06/spintrcritical06.scn, spintrcritical07/spintrcritical07.scn, spintrcritical11/spintrcritical11.scn, spintrcritical12/spintrcritical12.scn, spintrcritical13/spintrcritical13.scn, spintrcritical14/spintrcritical14.scn: Update.
* fixed some typosThomas Doerfler2009-11-301-1/+1
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-121-1/+0
| | | | | | | | | | | | | | | * sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c, sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c, sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c, sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c, sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c, spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second().
* 2009-08-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-111-0/+1
| | | | | * spintrcritical01/init.c, spintrcritical06/init.c: Use 1 millisecond per tick.
* 2009-08-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-061-0/+1
| | | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds per tick so tests run quicker and more reliably hit the intended critical section.
* 2009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-231-0/+1
| | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical09/init.c: Perform some cleanup and make the tests more similar.
* 2009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-231-20/+3
| | | | * spintrcritical06/init.c: Test now hits forward and reverse cases.
* 2009-07-21 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-211-9/+2
| | | | | | * spintrcritical06/init.c: Clean up. * spintrcritical09/init.c: Adjust clock tick so it works on erc32. * spintrcritical09/spintrcritical09.scn: Fill in.
* 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-211-2/+16
| | | | | | | | | | | | | * spintrcritical06/init.c: Add comment to indicate test is not finished and known to not hit the case. * Makefile.am, configure.ac: Add a couple more interrupt critical section tests. * spintrcritical08/.cvsignore, spintrcritical08/Makefile.am, spintrcritical08/init.c, spintrcritical08/spintrcritical08.doc, spintrcritical08/spintrcritical08.scn, spintrcritical09/.cvsignore, spintrcritical09/Makefile.am, spintrcritical09/init.c, spintrcritical09/spintrcritical09.doc, spintrcritical09/spintrcritical09.scn: New files.
* 2009-07-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-201-0/+9
| | | | | | | | | * Makefile.am, configure.ac, spintrcritical06/init.c: Add first attempt at hitting interrupt synchronization critical section in thread queue enqueue priority for reverse insertions. * spintrcritical07/.cvsignore, spintrcritical07/Makefile.am, spintrcritical07/spintrcritical07.doc, spintrcritical07/spintrcritical07.scn: New files.
* 2009-07-20 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-205-0/+221
* Makefile.am, configure.ac: Add test case for the _Thread_queue_Enqueue_priority interrupt critical section where the TCB we are using as a current pointer is removed from the thread queue when we flash interrupts while searching forward. * spintrcritical06/.cvsignore, spintrcritical06/Makefile.am, spintrcritical06/init.c, spintrcritical06/spintrcritical06.doc, spintrcritical06/spintrcritical06.scn: New files.
