* spintrcritical01/Makefile.am, spintrcritical06/Makefile.am,
spintrcritical08/Makefile.am, spintrcritical09/Makefile.am,
spintrcritical10/Makefile.am, spintrcritical11/Makefile.am,
spintrcritical13/Makefile.am, spintrcritical15/Makefile.am,
spintrcritical16/Makefile.am, spintrcritical17/Makefile.am:
Add ../spintrcritical_support/intrcritical.h to *_SOURCES.
* spintrcritical01/init.c: Fixed warning fix.
* sp09/screen12.c, sp09/sp09.scn, sp21/Makefile.am, sp35/priinv.c,
sp39/init.c, sp50/init.c, sp57/init.c, sp72/init.c, sp73/init.c,
spintrcritical01/init.c, spprivenv01/init.c, spsimplesched01/init.c,
spsimplesched02/init.c: Remove warnings.
* spintrcritical01/init.c, spintrcritical06/init.c: Use 1 millisecond
per tick.
* spintrcritical01/init.c, spintrcritical06/init.c,
spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds
per tick so tests run quicker and more reliably hit the intended
critical section.
spintrcritical08/init.c, spintrcritical09/init.c: Perform some
cleanup and make the tests more similar.
* Makefile.am, configure.ac: Add new infrastructure which is more
reliable about generating cases which hit interrupt critical
sections. Remove sp41 since it used its own mechanism.
* spintrcritical01/.cvsignore, spintrcritical01/Makefile.am,
spintrcritical01/init.c, spintrcritical01/spintrcritical01.doc,
spintrcritical01/spintrcritical01.scn, spintrcritical02/.cvsignore,
spintrcritical02/Makefile.am, spintrcritical02/spintrcritical02.doc,
spintrcritical02/spintrcritical02.scn, spintrcritical03/.cvsignore,
spintrcritical03/Makefile.am, spintrcritical03/spintrcritical03.doc,
spintrcritical03/spintrcritical03.scn, spintrcritical04/.cvsignore,
spintrcritical04/Makefile.am, spintrcritical04/spintrcritical04.doc,
spintrcritical04/spintrcritical04.scn, spintrcritical05/.cvsignore,
spintrcritical05/Makefile.am, spintrcritical05/spintrcritical05.doc,
spintrcritical05/spintrcritical05.scn: New files.
* sp41/.cvsignore, sp41/Makefile.am, sp41/init.c, sp41/sp41.scn,
sp41/system.h: Removed.
