path: root/testsuites/sptests/spintrcritical01 (follow)
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-201-0/+1
| | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES.
* 2011-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-201-1/+1
| | | | * spintrcritical01/init.c: Fixed warning fix.
* 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-051-1/+3
| | | | | | | * sp09/screen12.c, sp09/sp09.scn, sp21/Makefile.am, sp35/priinv.c, sp39/init.c, sp50/init.c, sp57/init.c, sp72/init.c, sp73/init.c, spintrcritical01/init.c, spprivenv01/init.c, spsimplesched01/init.c, spsimplesched02/init.c: Remove warnings.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* Whitespace removal.Ralf Corsepius2009-11-301-2/+2
* 2009-08-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-111-0/+1
| | | | | * spintrcritical01/init.c, spintrcritical06/init.c: Use 1 millisecond per tick.
* 2009-08-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-061-0/+1
| | | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds per tick so tests run quicker and more reliably hit the intended critical section.
* 2009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-231-2/+5
| | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical09/init.c: Perform some cleanup and make the tests more similar.
* 2009-07-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-105-0/+207
* Makefile.am, configure.ac: Add new infrastructure which is more reliable about generating cases which hit interrupt critical sections. Remove sp41 since it used its own mechanism. * spintrcritical01/.cvsignore, spintrcritical01/Makefile.am, spintrcritical01/init.c, spintrcritical01/spintrcritical01.doc, spintrcritical01/spintrcritical01.scn, spintrcritical02/.cvsignore, spintrcritical02/Makefile.am, spintrcritical02/spintrcritical02.doc, spintrcritical02/spintrcritical02.scn, spintrcritical03/.cvsignore, spintrcritical03/Makefile.am, spintrcritical03/spintrcritical03.doc, spintrcritical03/spintrcritical03.scn, spintrcritical04/.cvsignore, spintrcritical04/Makefile.am, spintrcritical04/spintrcritical04.doc, spintrcritical04/spintrcritical04.scn, spintrcritical05/.cvsignore, spintrcritical05/Makefile.am, spintrcritical05/spintrcritical05.doc, spintrcritical05/spintrcritical05.scn: New files. * sp41/.cvsignore, sp41/Makefile.am, sp41/init.c, sp41/sp41.scn, sp41/system.h: Removed.
