path: root/testsuites/sptests/spintrcritical01 (follow)
* spintrcritical01/2/3/4/5: Use T_interrupt_test()Sebastian Huber2020-07-232-61/+90
* sptests: Avoid build system defined definesSebastian Huber2019-11-122-155/+157
| | | | Update #3818.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-25/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* score: New thread queue implementationSebastian Huber2015-05-191-23/+15
| | | | | | | | | Use thread wait flags for synchronization. The enqueue operation is now part of the initial critical section. This is the key change and enables fine grained locking on SMP for objects using a thread queue like semaphores and message queues. Update #2273.
* tests: Rework interrupt critical testsSebastian Huber2014-09-101-19/+19
| | | | | | | | | This avoids test durations of more than one hour on fast targets, since fast targets can count a lot during one clock tick period, so the minor loop iteration count was quite high. Estimate now the test body duration to iterate only through the interesting time window. Add and use interrupt_critical_section_test().
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-7/+11
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* rtems: Create semaphore implementation headerSebastian Huber2013-07-181-1/+2
| | | | | | Move implementation specific parts of sem.h and sem.inl into new header file semimpl.h. The sem.h contains now only the application visible API.
* sptests - Eliminate missing prototype warningsJoel Sherrill2012-05-311-1/+6
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-201-0/+1
| | | | | | | | | * spintrcritical01/Makefile.am, spintrcritical06/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical13/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am: Add ../spintrcritical_support/intrcritical.h to *_SOURCES.
* 2011-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-201-1/+1
| | | | * spintrcritical01/init.c: Fixed warning fix.
* 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-051-1/+3
| | | | | | | * sp09/screen12.c, sp09/sp09.scn, sp21/Makefile.am, sp35/priinv.c, sp39/init.c, sp50/init.c, sp57/init.c, sp72/init.c, sp73/init.c, spintrcritical01/init.c, spprivenv01/init.c, spsimplesched01/init.c, spsimplesched02/init.c: Remove warnings.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* Whitespace removal.Ralf Corsepius2009-11-301-2/+2
* 2009-08-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-111-0/+1
| | | | | * spintrcritical01/init.c, spintrcritical06/init.c: Use 1 millisecond per tick.
* 2009-08-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-061-0/+1
| | | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds per tick so tests run quicker and more reliably hit the intended critical section.
* 2009-07-23 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-231-2/+5
| | | | | | * spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical09/init.c: Perform some cleanup and make the tests more similar.
* 2009-07-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-105-0/+207
* Makefile.am, configure.ac: Add new infrastructure which is more reliable about generating cases which hit interrupt critical sections. Remove sp41 since it used its own mechanism. * spintrcritical01/.cvsignore, spintrcritical01/Makefile.am, spintrcritical01/init.c, spintrcritical01/spintrcritical01.doc, spintrcritical01/spintrcritical01.scn, spintrcritical02/.cvsignore, spintrcritical02/Makefile.am, spintrcritical02/spintrcritical02.doc, spintrcritical02/spintrcritical02.scn, spintrcritical03/.cvsignore, spintrcritical03/Makefile.am, spintrcritical03/spintrcritical03.doc, spintrcritical03/spintrcritical03.scn, spintrcritical04/.cvsignore, spintrcritical04/Makefile.am, spintrcritical04/spintrcritical04.doc, spintrcritical04/spintrcritical04.scn, spintrcritical05/.cvsignore, spintrcritical05/Makefile.am, spintrcritical05/spintrcritical05.doc, spintrcritical05/spintrcritical05.scn: New files. * sp41/.cvsignore, sp41/Makefile.am, sp41/init.c, sp41/sp41.scn, sp41/system.h: Removed.
