* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 3 | -3/+3 |
* | raspberrypi: Use shared bspreset.c | Joel Sherrill | 2014-09-04 | 1 | -33/+32 |
* | score: Statically initialize _ISR_Vector_table | Sebastian Huber | 2014-04-29 | 1 | -1/+1 |
* | spintr_err01: New test split from sp09. | Bjorn Larsson | 2014-03-28 | 6 | -0/+215 |
This test contains the interrupt catch error tests from sp09 screen 9. |
