path: root/testsuites/sptests/spinternalerror01 (follow)
* Rename is_internal to always_set_to_falseSebastian Huber2016-12-121-2/+6
| | | | Update #2825.
* score: Remove fatal is internal indicatorSebastian Huber2016-12-091-8/+2
| | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825.
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-4/+5
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* score: Static scheduler configurationSebastian Huber2014-04-151-3/+3
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-3/+9
* score: Rename _Internal_error_Occurred()Sebastian Huber2014-02-212-3/+3
| | | | Rename _Internal_error_Occurred() into _Terminate().
* testsuites: Fix warningsSebastian Huber2013-04-111-2/+0
* score: rtems_initialize_start_multitasking()Sebastian Huber2012-12-071-1/+1
| | | | | | | | | Do not return from rtems_initialize_start_multitasking() and call rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and a fatal code with the exit status. Remove all bsp_cleanup() functions. The boot_card() is now a no return function.
* sptests/spinternalerror01: New testSebastian Huber2012-11-134-0/+119
