path: root/testsuites/sptests/spglobalcon01 (follow)
* spglobalcon01: LLVM optimization makes variable i always 1Daniel Hellstrom2018-08-241-2/+2
| | | | | Declare i volatile to avoid compiler optimization putting i into data section with initialization value 1.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-19/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove obsolete TESTS_USE_PRINTKSebastian Huber2017-10-281-1/+0
* testsuites: Avoid clock driverSebastian Huber2014-10-141-1/+1
* score: Rework global constructionSebastian Huber2014-10-134-0/+94
Ensure that the global construction is performed in the context of the first initialization thread. On SMP this was not guaranteed in the previous implementation.
