path: root/testsuites/sptests/spfreechain01 (follow)
* score: Add <rtems/score/freechainimpl.h>Sebastian Huber2020-08-311-1/+1
| | | | | | Hide implementation details. Update #3959.
* score: Add _Freechain_Pop()Sebastian Huber2020-02-121-0/+4
| | | | Update #3835.
* score: Add _Freechain_Is_empty()Sebastian Huber2020-02-121-1/+2
| | | | Update #3835.
* score: Static Objects_Information initializationSebastian Huber2018-12-141-3/+6
| | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* score: Accept NULL pointer in _Freechain_Put()Sebastian Huber2015-07-011-0/+2
| | | | With this a _Freechain_Put( _Freechain_Get() ) works always.
* score: Freechain handler API changesSebastian Huber2015-07-012-152/+19
| | | | | Replace the extend function with an allocator since this fits better to the current use case.
* spfreechain01/init.c: Use %zd for size_t to eliminate warningJoel Sherrill2014-09-041-2/+2
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* Fix a bug in spfreechain01 test case.Zhongwei Yao2013-08-111-2/+2
* sptests/spfreechain01: Fix Makefile.amCynthia Rempel2013-08-041-0/+2
* score: Add freechainZhongwei Yao2013-07-244-0/+254
