Updates #3053.
Hide implementation details.
Update #3959.
Update #3835.
Update #3835.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
With this a _Freechain_Put( _Freechain_Get() ) works always.
Replace the extend function with an allocator since this fits better
to the current use case.
