* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -1/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -1/+4 |
* | 2010-07-02 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-07-02 | 5 | -0/+172 |
| | | | | | | | | PR 1600/testing * spfifo04/init.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/Makefile.am: New files to improve coverage on fifo/pipe routines * Makefile.am, configure.ac: Add new test. | ||||
* | 2010-06-24 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 2010-06-24 | 5 | -262/+0 |
| | | | | | | | | | | | | | | | | * Makefile.am, configure.ac: Removed some fifo tests. * spfifo01/Makefile.am, spfifo01/init.c: Minor changes to avoid excessive new lines in the output. spfifo02/Makefile.am, spfifo02/init.c, spfifo02/spfifo02.doc, spfifo02/spfifo02.scn, spfifo03/Makefile.am: Merge from spfifo08. Also added a few more cases, mostly from spfifo04/init.c. * spfifo03/init.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn: Previously was spfifo06. Configure parameter for pipes is used now. * spfifo04/.cvsignore, spfifo04/Makefile.am, spfifo04/init.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo08/.cvsignore, spfifo08/Makefile.am, spfifo08/init.c, spfifo08/spfifo08.doc, spfifo08/spfifo08.scn: Removed. | ||||
* | 2010-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-20 | 1 | -1/+1 |
| | | | | | * spfifo02/init.c, spfifo03/init.c, spfifo04/init.c: Configure pipes used. | ||||
* | 2010-06-10 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2010-06-10 | 2 | -4/+4 |
| | | | | | | * spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c, spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc, spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright. | ||||
* | 2010-06-08 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2010-06-08 | 3 | -64/+29 |
| | | | | | | | | | | | * spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am: Merged fifo main and test files into the standard init file. Fixed copyright information. * spfifo01/init.c, spfifo02/init.c, spfifo03/init.c, spfifo04/init.c: New files. * spfifo01/main.c, spfifo01/test.c, spfifo02/main.c, spfifo02/test.c, spfifo03/main.c, spfifo03/test.c, spfifo04/main.c, spfifo04/test.c: Removed. | ||||
* | 2010-06-08 Jennifer Averett <Jennifer.Averett@OARcorp.com | Jennifer Averett | 2010-06-08 | 1 | -0/+2 |
| | | | | | * spfifo01/.cvsignore, spfifo02/.cvsignore, spfifo03/.cvsignore, spfifo04/.cvsignore: New files. | ||||
* | 2010-06-07 Bharath Suri <bharath.s.jois@gmail.com> | Jennifer Averett | 2010-06-07 | 5 | -0/+295 |
PR PR1542 * Makefile.am, configure.ac: Coverage improvement: fifo_open. * spfifo01/spfifo01.doc, spfifo01/spfifo01.scn, spfifo01/test.c, spfifo02/Makefile.am, spfifo02/main.c, spfifo02/spfifo02.doc, spfifo02/spfifo02.scn, spfifo02/test.c, spfifo03/Makefile.am, spfifo03/main.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn, spfifo03/test.c, spfifo04/Makefile.am, spfifo04/main.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/test.c: New files. |
