Updates #3053.
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Update #3753.
Obsolete undocumented configuration options CONFIGURE_MAXIMUM_FIFOS and
CONFIGURE_MAXIMUM_PIPES. Replace these options with the new
CONFIGURE_IMFS_ENABLE_MKFIFO configuration option.
Update #3840.
It is unnecessary to run these test cases with interrupts disabled.
Update #3533.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
* Makefile.am, configure.ac: Removed some fifo tests.
* spfifo01/Makefile.am, spfifo01/init.c: Minor changes to avoid
excessive new lines in the output.
spfifo02/Makefile.am, spfifo02/init.c, spfifo02/spfifo02.doc,
spfifo02/spfifo02.scn, spfifo03/Makefile.am: Merge from spfifo08.
Also added a few more cases, mostly from spfifo04/init.c.
* spfifo03/init.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn:
Previously was spfifo06. Configure parameter for pipes is used now.
* spfifo04/.cvsignore, spfifo04/Makefile.am, spfifo04/init.c,
spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo08/.cvsignore,
spfifo08/Makefile.am, spfifo08/init.c, spfifo08/spfifo08.doc,
spfifo08/spfifo08.scn: Removed.
* spfifo02/init.c, spfifo03/init.c, spfifo04/init.c: Configure pipes
used.
* spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c,
spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc,
spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright.
* spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am: Merged fifo main and test files into the
standard init file. Fixed copyright information.
* spfifo01/init.c, spfifo02/init.c, spfifo03/init.c, spfifo04/init.c:
New files.
* spfifo01/main.c, spfifo01/test.c, spfifo02/main.c, spfifo02/test.c,
spfifo03/main.c, spfifo03/test.c, spfifo04/main.c, spfifo04/test.c:
Removed.
PR PR1542
* Makefile.am, configure.ac: Coverage improvement: fifo_open.
* spfifo01/spfifo01.doc, spfifo01/spfifo01.scn, spfifo01/test.c,
spfifo02/Makefile.am, spfifo02/main.c, spfifo02/spfifo02.doc,
spfifo02/spfifo02.scn, spfifo02/test.c, spfifo03/Makefile.am,
spfifo03/main.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn,
spfifo03/test.c, spfifo04/Makefile.am, spfifo04/main.c,
spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/test.c: New
files.
