2022-04-05 | testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2019-12-11 | pipe: Use condition variables | Sebastian Huber | 1 | -1/+0 | |
Use self-contained condition variables instead of Classic API barriers. This simplifies the implementation and configuration. Update #3840. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2010-06-24 | 2010-06-24 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | 1 | -8/+10 | |
* Makefile.am, configure.ac: Removed some fifo tests. * spfifo01/Makefile.am, spfifo01/init.c: Minor changes to avoid excessive new lines in the output. spfifo02/Makefile.am, spfifo02/init.c, spfifo02/spfifo02.doc, spfifo02/spfifo02.scn, spfifo03/Makefile.am: Merge from spfifo08. Also added a few more cases, mostly from spfifo04/init.c. * spfifo03/init.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn: Previously was spfifo06. Configure parameter for pipes is used now. * spfifo04/.cvsignore, spfifo04/Makefile.am, spfifo04/init.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo08/.cvsignore, spfifo08/Makefile.am, spfifo08/init.c, spfifo08/spfifo08.doc, spfifo08/spfifo08.scn: Removed. | |||||
2010-06-10 | 2010-06-10 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 1 | -2/+2 | |
* spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c, spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc, spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright. | |||||
2010-06-07 | 2010-06-07 Bharath Suri <bharath.s.jois@gmail.com> | Jennifer Averett | 1 | -6/+6 | |
PR PR1542 * Makefile.am, configure.ac: Coverage improvement: fifo_open. * spfifo01/spfifo01.doc, spfifo01/spfifo01.scn, spfifo01/test.c, spfifo02/Makefile.am, spfifo02/main.c, spfifo02/spfifo02.doc, spfifo02/spfifo02.scn, spfifo02/test.c, spfifo03/Makefile.am, spfifo03/main.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn, spfifo03/test.c, spfifo04/Makefile.am, spfifo04/main.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/test.c: New files. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. |
