* Makefile.am, configure.ac: Removed some fifo tests.
* spfifo01/Makefile.am, spfifo01/init.c: Minor changes to avoid
excessive new lines in the output.
spfifo02/Makefile.am, spfifo02/init.c, spfifo02/spfifo02.doc,
spfifo02/spfifo02.scn, spfifo03/Makefile.am: Merge from spfifo08.
Also added a few more cases, mostly from spfifo04/init.c.
* spfifo03/init.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn:
Previously was spfifo06. Configure parameter for pipes is used now.
* spfifo04/.cvsignore, spfifo04/Makefile.am, spfifo04/init.c,
spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo08/.cvsignore,
spfifo08/Makefile.am, spfifo08/init.c, spfifo08/spfifo08.doc,
spfifo08/spfifo08.scn: Removed.
* spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c,
spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc,
spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright.
PR PR1542
* Makefile.am, configure.ac: Coverage improvement: fifo_open.
* spfifo01/spfifo01.doc, spfifo01/spfifo01.scn, spfifo01/test.c,
spfifo02/Makefile.am, spfifo02/main.c, spfifo02/spfifo02.doc,
spfifo02/spfifo02.scn, spfifo02/test.c, spfifo03/Makefile.am,
spfifo03/main.c, spfifo03/spfifo03.doc, spfifo03/spfifo03.scn,
spfifo03/test.c, spfifo04/Makefile.am, spfifo04/main.c,
spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/test.c: New
files.
