* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -21/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED | Sebastian Huber | 2016-12-12 | 1 | -2/+2 |
| | | | | Update #2825. | ||||
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -1/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | tests/fatal: Fix test names | Sebastian Huber | 2014-03-31 | 1 | -1/+1 |
* | privateenv: Use POSIX keys instead of task variables. | Christian Mauderer | 2014-03-27 | 4 | -0/+74 |
