2020-02-25 | libio: Add POSIX user environment pointer to TCB | Sebastian Huber | 1 | -3/+0 | |
The IO library used a POSIX key to store an optional POSIX user environment pointer. This pulled in the POSIX keys support in every application configuration. Add a user environment pointer to the thread control block (TCB) instead. Applications which do not need the POSIX user environment will just get an overhead of one pointer per thread. Close #3882. | |||||
2014-03-27 | privateenv: Use POSIX keys instead of task variables. | Christian Mauderer | 1 | -0/+3 | |
