* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Filesystem: Remove per file descriptor semaphore | Sebastian Huber | 2012-05-04 | 1 | -1/+1 |
| | | | | | | | | | The per file descriptor semaphore (field of rtems_libio_t) is unused in RTEMS. There is a considerable memory overhead due to that. A semaphore needs roughly 124 bytes which is huge compared to the approximately 72 bytes for the file descriptor structure itself. Device drivers can create their own synchronization primitives in the open handler on demand. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-09-05 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-05 | 1 | -0/+1 |
| | | | | | | | | | * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn, spfatal_support/init.c: Print proper begin message. | ||||
* | 2011-08-22 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-08-22 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | * spfatal13/testcase.h: Fixed test name. * spfatal05/testcase.h: Increased wait time for slow hardware. * spfatal_support/init.c: Print test name at end of test. * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal03/spfatal03.scn, spfatal04/spfatal04.scn, spfatal05/spfatal05.scn, spfatal06/spfatal06.scn, spfatal07/spfatal07.scn, spfatal08/spfatal08.scn, spfatal09/spfatal09.scn, spfatal10/spfatal10.scn, spfatal11/spfatal11.scn, spfatal12/spfatal12.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn, spfatal21/spfatal21.scn, spfatal22/spfatal22.scn, spfatal23/spfatal23.scn, spfatal24/spfatal24.scn, spfatal25/spfatal25.scn: Reflect changes from above. | ||||
* | 2010-07-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-07 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | | | | | * spfatal09/.cvsignore, spfatal09/Makefile.am, spfatal09/spfatal09.doc, spfatal09/spfatal09.scn, spfatal09/testcase.h: Removed files. * Makefile.am, configure.ac: Reflect changes above. * spfatal_support/init.c: Print end of test message in case of success. Stop multitasking in the fatal error extension. * spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of puts(). * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal03/spfatal03.scn, spfatal04/spfatal04.scn, spfatal05/spfatal05.scn, spfatal06/spfatal06.scn, spfatal07/spfatal07.scn, spfatal08/spfatal08.scn, spfatal10/spfatal10.scn, spfatal11/spfatal11.scn, spfatal12/spfatal12.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn: Update. | ||||
* | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-22 | 5 | -0/+82 |
* Makefile.am, configure.ac: Add new tests to generate fatal errors in rtems_termios_open(). * spfatal16/.cvsignore, spfatal16/Makefile.am, spfatal16/spfatal16.doc, spfatal16/spfatal16.scn, spfatal16/testcase.h, spfatal17/.cvsignore, spfatal17/Makefile.am, spfatal17/spfatal17.doc, spfatal17/spfatal17.scn, spfatal17/testcase.h, spfatal18/.cvsignore, spfatal18/Makefile.am, spfatal18/spfatal18.doc, spfatal18/spfatal18.scn, spfatal18/testcase.h, spfatal19/.cvsignore, spfatal19/Makefile.am, spfatal19/spfatal19.doc, spfatal19/spfatal19.scn, spfatal19/testcase.h: New files. |
