* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -1/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-22 | 1 | -0/+28 |
* Makefile.am, configure.ac: Add new tests to generate fatal errors in rtems_termios_open(). * spfatal16/.cvsignore, spfatal16/Makefile.am, spfatal16/spfatal16.doc, spfatal16/spfatal16.scn, spfatal16/testcase.h, spfatal17/.cvsignore, spfatal17/Makefile.am, spfatal17/spfatal17.doc, spfatal17/spfatal17.scn, spfatal17/testcase.h, spfatal18/.cvsignore, spfatal18/Makefile.am, spfatal18/spfatal18.doc, spfatal18/spfatal18.scn, spfatal18/testcase.h, spfatal19/.cvsignore, spfatal19/Makefile.am, spfatal19/spfatal19.doc, spfatal19/spfatal19.scn, spfatal19/testcase.h: New files. |
