The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Update #3818.
Update #3382
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
for details.
PR 1589/build
sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am,
sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am,
sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am,
sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am,
sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am,
sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am,
sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am,
sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am,
sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am,
sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am,
sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am,
sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am,
sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am,
sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am,
sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am,
sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am,
sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am,
sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am,
sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am,
sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am,
sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am,
spcbssched01/Makefile.am, spcbssched02/Makefile.am,
spcbssched03/Makefile.am, spchain/Makefile.am,
spclockget/Makefile.am, spcoverage/Makefile.am,
spedfsched01/Makefile.am, spedfsched02/Makefile.am,
spedfsched03/Makefile.am, sperror01/Makefile.am,
sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am,
spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am,
spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am,
spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am,
spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am,
spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am,
spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am,
spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am,
spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am,
spintrcritical01/Makefile.am, spintrcritical02/Makefile.am,
spintrcritical03/Makefile.am, spintrcritical04/Makefile.am,
spintrcritical05/Makefile.am, spintrcritical06/Makefile.am,
spintrcritical07/Makefile.am, spintrcritical08/Makefile.am,
spintrcritical09/Makefile.am, spintrcritical10/Makefile.am,
spintrcritical11/Makefile.am, spintrcritical12/Makefile.am,
spintrcritical13/Makefile.am, spintrcritical14/Makefile.am,
spintrcritical15/Makefile.am, spintrcritical16/Makefile.am,
spintrcritical17/Makefile.am, spmkdir/Makefile.am,
spmountmgr01/Makefile.am, spnotepad01/Makefile.am,
spnsext01/Makefile.am, spobjgetnext/Makefile.am,
spprintk/Makefile.am, spprivenv01/Makefile.am,
sprbtree01/Makefile.am, spsimplesched01/Makefile.am,
spsimplesched02/Makefile.am, spsimplesched03/Makefile.am,
spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am,
spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete
optional manager capability.
PR 1924/cpukit
* sptests/spfatal08/testcase.h, sptests/spfatal12/testcase.h: Update
due to API changes.
* spfatal13/testcase.h: Fixed test name.
* spfatal05/testcase.h: Increased wait time for slow hardware.
* spfatal_support/init.c: Print test name at end of test.
* spfatal01/spfatal01.scn, spfatal02/spfatal02.scn,
spfatal03/spfatal03.scn, spfatal04/spfatal04.scn,
spfatal05/spfatal05.scn, spfatal06/spfatal06.scn,
spfatal07/spfatal07.scn, spfatal08/spfatal08.scn,
spfatal09/spfatal09.scn, spfatal10/spfatal10.scn,
spfatal11/spfatal11.scn, spfatal12/spfatal12.scn,
spfatal13/spfatal13.scn, spfatal14/spfatal14.scn,
spfatal15/spfatal15.scn, spfatal16/spfatal16.scn,
spfatal17/spfatal17.scn, spfatal18/spfatal18.scn,
spfatal19/spfatal19.scn, spfatal20/spfatal20.scn,
spfatal21/spfatal21.scn, spfatal22/spfatal22.scn,
spfatal23/spfatal23.scn, spfatal24/spfatal24.scn,
spfatal25/spfatal25.scn: Reflect changes from above.
* spfatal09/.cvsignore, spfatal09/Makefile.am,
spfatal09/spfatal09.doc, spfatal09/spfatal09.scn,
spfatal09/testcase.h: Removed files.
* Makefile.am, configure.ac: Reflect changes above.
* spfatal_support/init.c: Print end of test message in case of
success. Stop multitasking in the fatal error extension.
* spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of
puts().
spfatal10/spfatal10.scn, spfatal11/spfatal11.scn,
spfatal12/spfatal12.scn, spfatal13/spfatal13.scn,
spfatal14/spfatal14.scn, spfatal15/spfatal15.scn,
spfatal16/spfatal16.scn, spfatal17/spfatal17.scn,
spfatal18/spfatal18.scn, spfatal19/spfatal19.scn,
spfatal20/spfatal20.scn: Update.
* spfatal01/spfatal01.scn, spfatal01/testcase.h,
spfatal02/spfatal02.scn, spfatal02/testcase.h,
spfatal03/spfatal03.scn, spfatal03/testcase.h,
spfatal04/spfatal04.scn, spfatal04/testcase.h,
spfatal05/spfatal05.scn, spfatal05/testcase.h,
spfatal06/spfatal06.scn, spfatal06/testcase.h,
spfatal07/spfatal07.scn, spfatal07/testcase.h,
spfatal08/spfatal08.scn, spfatal08/testcase.h,
spfatal09/spfatal09.scn, spfatal09/testcase.h, spfatal10/Makefile.am,
spfatal10/spfatal10.scn, spfatal11/Makefile.am,
spfatal11/spfatal11.scn, spfatal12/Makefile.am,
spfatal12/spfatal12.scn, spfatal_support/init.c: Make all fatal error
tests use testcase.h and spfatal_support framework. Print test name
herald in all cases.
* spfatal10/testcase.h, spfatal11/testcase.h, spfatal12/testcase.h:
New files.
* spfatal10/init.c, spfatal11/init.c, spfatal12/init.c: Removed.
* sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am,
sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded
USE_TIMER_SERVER which was copied fomr other Makefile.am's.
* spfatal12/init.c: Address to heap initialize must be aligned but size
must be too small.
* Makefile.am, configure.ac, spfatal11/init.c: Add test of cannot
initialize workspace heap during initialize. Can be caused by
unaligned address or not enough memory to initialize heap required
overhead.
* spfatal12/.cvsignore, spfatal12/Makefile.am, spfatal12/init.c,
spfatal12/spfatal12.doc, spfatal12/spfatal12.scn: New files.
