* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-08-22 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-08-22 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | * spfatal13/testcase.h: Fixed test name. * spfatal05/testcase.h: Increased wait time for slow hardware. * spfatal_support/init.c: Print test name at end of test. * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal03/spfatal03.scn, spfatal04/spfatal04.scn, spfatal05/spfatal05.scn, spfatal06/spfatal06.scn, spfatal07/spfatal07.scn, spfatal08/spfatal08.scn, spfatal09/spfatal09.scn, spfatal10/spfatal10.scn, spfatal11/spfatal11.scn, spfatal12/spfatal12.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn, spfatal21/spfatal21.scn, spfatal22/spfatal22.scn, spfatal23/spfatal23.scn, spfatal24/spfatal24.scn, spfatal25/spfatal25.scn: Reflect changes from above. | ||||
* | 2010-07-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-07 | 1 | -3/+2 |
| | | | | | | | | | | | | | | | | | | | | | * spfatal09/.cvsignore, spfatal09/Makefile.am, spfatal09/spfatal09.doc, spfatal09/spfatal09.scn, spfatal09/testcase.h: Removed files. * Makefile.am, configure.ac: Reflect changes above. * spfatal_support/init.c: Print end of test message in case of success. Stop multitasking in the fatal error extension. * spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of puts(). * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal03/spfatal03.scn, spfatal04/spfatal04.scn, spfatal05/spfatal05.scn, spfatal06/spfatal06.scn, spfatal07/spfatal07.scn, spfatal08/spfatal08.scn, spfatal10/spfatal10.scn, spfatal11/spfatal11.scn, spfatal12/spfatal12.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn: Update. | ||||
* | 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-12-08 | 1 | -0/+2 |
| | | | | | | | | * sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c, spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c, spwkspace/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-04 | 4 | -41/+28 |
| | | | | | | | | | | | | | | | | | | | | * spfatal01/spfatal01.scn, spfatal01/testcase.h, spfatal02/spfatal02.scn, spfatal02/testcase.h, spfatal03/spfatal03.scn, spfatal03/testcase.h, spfatal04/spfatal04.scn, spfatal04/testcase.h, spfatal05/spfatal05.scn, spfatal05/testcase.h, spfatal06/spfatal06.scn, spfatal06/testcase.h, spfatal07/spfatal07.scn, spfatal07/testcase.h, spfatal08/spfatal08.scn, spfatal08/testcase.h, spfatal09/spfatal09.scn, spfatal09/testcase.h, spfatal10/Makefile.am, spfatal10/spfatal10.scn, spfatal11/Makefile.am, spfatal11/spfatal11.scn, spfatal12/Makefile.am, spfatal12/spfatal12.scn, spfatal_support/init.c: Make all fatal error tests use testcase.h and spfatal_support framework. Print test name herald in all cases. * spfatal10/testcase.h, spfatal11/testcase.h, spfatal12/testcase.h: New files. * spfatal10/init.c, spfatal11/init.c, spfatal12/init.c: Removed. | ||||
* | 2009-07-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-08 | 1 | -1/+0 |
| | | | | | | | * sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded USE_TIMER_SERVER which was copied fomr other Makefile.am's. | ||||
* | 2009-07-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-06 | 1 | -2/+1 |
| | | | | | | | | | * Makefile.am, configure.ac, spfatal11/init.c: Add test of cannot initialize workspace heap during initialize. Can be caused by unaligned address or not enough memory to initialize heap required overhead. * spfatal12/.cvsignore, spfatal12/Makefile.am, spfatal12/init.c, spfatal12/spfatal12.doc, spfatal12/spfatal12.scn: New files. | ||||
* | 2009-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-06-24 | 5 | -0/+97 |
* Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn: Enhance spprintk. Add two new fatal error tests to cover __assert_func. * spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c, spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files. |
