* spfatal09/.cvsignore, spfatal09/Makefile.am,
spfatal09/spfatal09.doc, spfatal09/spfatal09.scn,
spfatal09/testcase.h: Removed files.
* Makefile.am, configure.ac: Reflect changes above.
* spfatal_support/init.c: Print end of test message in case of
success. Stop multitasking in the fatal error extension.
* spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of
puts().
* spfatal01/spfatal01.scn, spfatal02/spfatal02.scn,
spfatal03/spfatal03.scn, spfatal04/spfatal04.scn,
spfatal05/spfatal05.scn, spfatal06/spfatal06.scn,
spfatal07/spfatal07.scn, spfatal08/spfatal08.scn,
spfatal10/spfatal10.scn, spfatal11/spfatal11.scn,
spfatal12/spfatal12.scn, spfatal13/spfatal13.scn,
spfatal14/spfatal14.scn, spfatal15/spfatal15.scn,
spfatal16/spfatal16.scn, spfatal17/spfatal17.scn,
spfatal18/spfatal18.scn, spfatal19/spfatal19.scn,
spfatal20/spfatal20.scn: Update.
* sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c,
spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c,
spwkspace/init.c: Use rtems_test_assert() consistently instead of
system assert(). rtems_test_assert() is designed to integrate into
the RTEMS test suite infrastructure.
* spfatal01/spfatal01.scn, spfatal01/testcase.h,
spfatal02/spfatal02.scn, spfatal02/testcase.h,
spfatal03/spfatal03.scn, spfatal03/testcase.h,
spfatal04/spfatal04.scn, spfatal04/testcase.h,
spfatal05/spfatal05.scn, spfatal05/testcase.h,
spfatal06/spfatal06.scn, spfatal06/testcase.h,
spfatal07/spfatal07.scn, spfatal07/testcase.h,
spfatal08/spfatal08.scn, spfatal08/testcase.h,
spfatal09/spfatal09.scn, spfatal09/testcase.h, spfatal10/Makefile.am,
spfatal10/spfatal10.scn, spfatal11/Makefile.am,
spfatal11/spfatal11.scn, spfatal12/Makefile.am,
spfatal12/spfatal12.scn, spfatal_support/init.c: Make all fatal error
tests use testcase.h and spfatal_support framework. Print test name
herald in all cases.
* spfatal10/testcase.h, spfatal11/testcase.h, spfatal12/testcase.h:
New files.
* spfatal10/init.c, spfatal11/init.c, spfatal12/init.c: Removed.
* sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am,
sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded
USE_TIMER_SERVER which was copied fomr other Makefile.am's.
* Makefile.am, configure.ac, spfatal11/init.c: Add test of cannot
initialize workspace heap during initialize. Can be caused by
unaligned address or not enough memory to initialize heap required
overhead.
* spfatal12/.cvsignore, spfatal12/Makefile.am, spfatal12/init.c,
spfatal12/spfatal12.doc, spfatal12/spfatal12.scn: New files.
* Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn:
Enhance spprintk. Add two new fatal error tests to cover
__assert_func.
* spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c,
spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files.
