* spfatal13/testcase.h: Fixed test name.
* spfatal05/testcase.h: Increased wait time for slow hardware.
* spfatal_support/init.c: Print test name at end of test.
* spfatal01/spfatal01.scn, spfatal02/spfatal02.scn,
spfatal03/spfatal03.scn, spfatal04/spfatal04.scn,
spfatal05/spfatal05.scn, spfatal06/spfatal06.scn,
spfatal07/spfatal07.scn, spfatal08/spfatal08.scn,
spfatal09/spfatal09.scn, spfatal10/spfatal10.scn,
spfatal11/spfatal11.scn, spfatal12/spfatal12.scn,
spfatal13/spfatal13.scn, spfatal14/spfatal14.scn,
spfatal15/spfatal15.scn, spfatal16/spfatal16.scn,
spfatal17/spfatal17.scn, spfatal18/spfatal18.scn,
spfatal19/spfatal19.scn, spfatal20/spfatal20.scn,
spfatal21/spfatal21.scn, spfatal22/spfatal22.scn,
spfatal23/spfatal23.scn, spfatal24/spfatal24.scn,
spfatal25/spfatal25.scn: Reflect changes from above.
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c,
sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c,
sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c,
sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c,
sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c,
spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c:
Do not line length exceed 80 columns.
* spfatal09/.cvsignore, spfatal09/Makefile.am,
spfatal09/spfatal09.doc, spfatal09/spfatal09.scn,
spfatal09/testcase.h: Removed files.
* Makefile.am, configure.ac: Reflect changes above.
* spfatal_support/init.c: Print end of test message in case of
success. Stop multitasking in the fatal error extension.
* spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of
puts().
spfatal10/spfatal10.scn, spfatal11/spfatal11.scn,
spfatal12/spfatal12.scn, spfatal13/spfatal13.scn,
spfatal14/spfatal14.scn, spfatal15/spfatal15.scn,
spfatal16/spfatal16.scn, spfatal17/spfatal17.scn,
spfatal18/spfatal18.scn, spfatal19/spfatal19.scn,
spfatal20/spfatal20.scn: Update.
* sp32/Makefile.am, sp33/Makefile.am, sp37/Makefile.am,
sp38/Makefile.am, sp39/Makefile.am, sp43/Makefile.am,
sp44/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am,
spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am,
spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am,
spfatal09/Makefile.am, spobjgetnext/Makefile.am,
spprintk/Makefile.am, spsize/Makefile.am, spwatchdog/Makefile.am,
spwkspace/Makefile.am: Add documentation files for multiple tests.
* sp32/sp32.doc, sp33/sp33.doc, sp37/sp37.doc, sp38/sp38.doc,
sp39/sp39.doc, sp43/sp43.doc, sp44/sp44.doc, spfatal01/spfatal01.doc,
spfatal02/spfatal02.doc, spfatal03/spfatal03.doc,
spfatal04/spfatal04.doc, spfatal05/spfatal05.doc,
spfatal06/spfatal06.doc, spfatal07/spfatal07.doc,
spfatal08/spfatal08.doc, spfatal09/spfatal09.doc,
spobjgetnext/spobjgetnext.doc, spprintk/spprintk.doc,
spsize/spsize.doc, spwatchdog/spwatchdog.doc,
spwkspace/spwkspace.doc: New files.
* spfatal01/spfatal01.scn, spfatal01/testcase.h,
spfatal02/spfatal02.scn, spfatal02/testcase.h,
spfatal03/spfatal03.scn, spfatal03/testcase.h,
spfatal04/spfatal04.scn, spfatal04/testcase.h,
spfatal05/spfatal05.scn, spfatal05/testcase.h,
spfatal06/spfatal06.scn, spfatal06/testcase.h,
spfatal07/spfatal07.scn, spfatal07/testcase.h,
spfatal08/spfatal08.scn, spfatal08/testcase.h,
spfatal09/spfatal09.scn, spfatal09/testcase.h, spfatal10/Makefile.am,
spfatal10/spfatal10.scn, spfatal11/Makefile.am,
spfatal11/spfatal11.scn, spfatal12/Makefile.am,
spfatal12/spfatal12.scn, spfatal_support/init.c: Make all fatal error
tests use testcase.h and spfatal_support framework. Print test name
herald in all cases.
* spfatal10/testcase.h, spfatal11/testcase.h, spfatal12/testcase.h:
New files.
* spfatal10/init.c, spfatal11/init.c, spfatal12/init.c: Removed.
* spfatal03/spfatal03.scn, spfatal03/testcase.h: Fix spfatal03 to do
what it was intended to do.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* spfatal01/.cvsignore, spfatal02/.cvsignore, spfatal03/.cvsignore,
spfatal04/.cvsignore, spfatal05/.cvsignore, spfatal06/.cvsignore,
spfatal07/.cvsignore, spfatal08/.cvsignore, spfatal09/.cvsignore:
New files.
* Makefile.am, configure.ac: Added fatal error tests
* spfatal01/Makefile.am, spfatal01/spfatal01.scn, spfatal01/testcase.h,
spfatal02/Makefile.am, spfatal02/spfatal02.scn, spfatal02/testcase.h,
spfatal03/Makefile.am, spfatal03/spfatal03.scn, spfatal03/testcase.h,
spfatal04/Makefile.am, spfatal04/spfatal04.scn, spfatal04/testcase.h,
spfatal05/Makefile.am, spfatal05/spfatal05.scn, spfatal05/testcase.h,
spfatal06/Makefile.am, spfatal06/spfatal06.scn, spfatal06/testcase.h,
spfatal07/Makefile.am, spfatal07/spfatal07.scn, spfatal07/testcase.h,
spfatal08/Makefile.am, spfatal08/spfatal08.scn, spfatal08/testcase.h,
spfatal09/Makefile.am, spfatal09/spfatal09.scn, spfatal09/testcase.h,
spfatal10/Makefile.am, spfatal10/spfatal10.scn, spfatal10/testcase.h,
spfatal_support/init.c, spfatal_support/system.h: New files.
