Update #3382
Update #3243.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #2692.
Use forward and reverse order for initial and dynamic extensions. This
is the behaviour documented in the C Users Guide. Change thread
terminate order to backward to be in line with the thread delete order.
Change fatal error order to forward to ensure that initial extensions
are called first due the peculiar execution context of fatal error
extensions, see _Terminate() documentation.
Update #2692.
Update #2825.
Update #2752.
of this patch set.
Add a lock and use a chain iterator for safe iteration during concurrent
user extension addition and removal.
Ensure that dynamically added thread delete and fatal extensions are
called in reverse order.
Update #2555.
Update #2692.
