* | sptests/spedfsched02: Reduce stack space usage to fix on smaller targets | Joel Sherrill | 2015-03-24 | 1 | -2/+0 |
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -0/+2 |
* | 2011-10-04 Sebastian Huber <sebastian.huber@embedded-brains.de> | Jennifer Averett | 2011-10-04 | 1 | -1/+1 |
| | | | | | | | PR 1922 * spcbssched02/system.h, spcbssched03/system.h, spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/system.h: EDF and CBS scheduler: extern declarations fix. | ||||
* | 2011-09-26 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-27 | 1 | -1/+1 |
| | | | | | | | PR 1923/testing * spcbssched02/spcbssched02.scn, spcbssched02/system.h, spcbssched03/init.c, spcbssched03/system.h, spedfsched02/system.h, spedfsched03/system.h, sprbtree01/init.c: Improve coverage. | ||||
* | 2011-09-11 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-11 | 1 | -0/+65 |
PR 1897/testing * Makefile.am, configure.ac: Add tests for Earliest Deadline First (EDF) Scheduling Algorithm implementation. * spedfsched01/.cvsignore, spedfsched01/Makefile.am, spedfsched01/init.c, spedfsched01/spedfsched01.doc, spedfsched01/spedfsched01.scn, spedfsched01/system.h, spedfsched01/task1.c, spedfsched02/.cvsignore, spedfsched02/Makefile.am, spedfsched02/getall.c, spedfsched02/init.c, spedfsched02/spedfsched02.doc, spedfsched02/spedfsched02.scn, spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/.cvsignore, spedfsched03/Makefile.am, spedfsched03/edfparams.h, spedfsched03/init.c, spedfsched03/spedfsched03.doc, spedfsched03/spedfsched03.scn, spedfsched03/system.h, spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c: New files. |
