TOD_MILLISECONDS_TO_TICKS().
* sp75/init.c, spcbssched01/init.c, spcbssched01/task1.c
spcbssched02/init.c, spcbssched02/task_periodic.c,
spcbssched03/init.c, spcbssched03/tasks_aperiodic.c,
spcbssched03/tasks_periodic.c, spedfsched01/init.c,
spedfsched01/task1.c, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/task1.c, spedfsched03/init.c,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c,
sprbtree01/init.c: Add HAVE_CONFIG_H.
PR 1897/testing
* Makefile.am, configure.ac: Add tests for Earliest Deadline First
(EDF) Scheduling Algorithm implementation.
* spedfsched01/.cvsignore, spedfsched01/Makefile.am,
spedfsched01/init.c, spedfsched01/spedfsched01.doc,
spedfsched01/spedfsched01.scn, spedfsched01/system.h,
spedfsched01/task1.c, spedfsched02/.cvsignore,
spedfsched02/Makefile.am, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/spedfsched02.doc, spedfsched02/spedfsched02.scn,
spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/.cvsignore,
spedfsched03/Makefile.am, spedfsched03/edfparams.h,
spedfsched03/init.c, spedfsched03/spedfsched03.doc,
spedfsched03/spedfsched03.scn, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c: New
files.
