* | spcpuset01: Reduce output to reduce run-time | Joel Sherrill | 2015-04-14 | 4 | -4045/+12 |
* | spcpuset01: fix test comments | Daniel Hellstrom | 2014-12-02 | 3 | -70/+70 |
* | spcpuset01: Use %zd for size_t to eliminate warning | Joel Sherrill | 2014-09-04 | 2 | -6/+6 |
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 2 | -4/+7 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | Remove trailing whitespace in previous patches | Jennifer Averett | 2014-03-07 | 2 | -6/+6 |
* | spcpuset01: Add check for sys/cpuset.h. | Jennifer Averett | 2014-03-07 | 3 | -10/+29 |
| | | | | | If <sys/cpuset.h> is not provided by the toolset, the test cannot be compiled. | ||||
* | sptests/spcpuset*: Add tests for fixed size cpu_set_t operations. | Jennifer Averett | 2013-12-19 | 6 | -0/+4402 |
This adds five tests for <sys/cpuset.h>. It does not include tests for CPU_XXX_S methods. The autotools should be able to avoid enabling the tests unless the toolset has <sys/cpuset.h>. |
