* | spcpuset01: Reduce output to reduce run-time | Joel Sherrill | 2015-04-14 | 1 | -5/+4 |
* | spcpuset01: Use %zd for size_t to eliminate warning | Joel Sherrill | 2014-09-04 | 1 | -4/+4 |
* | Remove trailing whitespace in previous patches | Jennifer Averett | 2014-03-07 | 1 | -5/+5 |
* | spcpuset01: Add check for sys/cpuset.h. | Jennifer Averett | 2014-03-07 | 1 | -3/+6 |
| | | | | | If <sys/cpuset.h> is not provided by the toolset, the test cannot be compiled. | ||||
* | sptests/spcpuset*: Add tests for fixed size cpu_set_t operations. | Jennifer Averett | 2013-12-19 | 1 | -0/+125 |
This adds five tests for <sys/cpuset.h>. It does not include tests for CPU_XXX_S methods. The autotools should be able to avoid enabling the tests unless the toolset has <sys/cpuset.h>. |
