The sbintime_t is an efficient time format. Add the ability to convert
CPU counter ticks to/from sbintime_t.
Update #3382
Update #3170.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Resurrect workaround accidentially removed by
3e2a3c49480b9888362d016dd202edd562d9e069.
Adjust test to work with clock driver based CPU counters. They have a
period equal to the clock tick interval.
