* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -1/+4 |
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2009-08-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-11 | 1 | -0/+41 |
* Makefile.am, configure.ac, sp62/init.c, sp64/init.c: Add new test and adjust existing for alignment. New test ensures coverage begin and end marker methods are exercised so they do not get considered unexecuted. * spcoverage/.cvsignore, spcoverage/Makefile.am, spcoverage/init.c, spcoverage/spcoverage.doc, spcoverage/spcoverage.scn: New files. |
