* | score: Fix CPU context usage on SMP | Sebastian Huber | 2014-05-08 | 1 | -0/+27 |
| | | | | | | | | | | We must not alter the is executing indicator in _CPU_Context_Initialize() since this would cause an invalid state during a self restart. The is executing indicator must be valid at creation time since otherwise _Thread_Kill_zombies() uses an undefined value for not started threads. This could result in a system life lock. | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 4 | -0/+220 |
